[Gdal-dev] swig/java dumps core
oland com at navicon.dk
Wed Oct 25 10:33:01 EDT 2006
Hello List
I have built the swing/java bindings in gdal-1.3.2. When I try to run the
gdalinfo java app it dumps core see below.
java -cp .:../gdal.jar -Djava.library.path=../.libs/ gdalinfo
/opt/Mapdata/BSB_ROOT/11006/11006_1.KAP
Driver: BSB/Maptech BSB Nautical Charts
Size is 10967, 9389
Coordinate System is:
Origin = (0.0,0.0)
Pixel Size = (1.0,1.0)
  0.0, 1.0, 0.0
  0.0, 0.0, 1.0
GCP Projection = GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG",7030]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG",6326]],PRIMEM["Greenwich",0,AUTHORITY["EPSG",8901]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG",9108]],AXIS["Lat",NORTH],AXIS["Long",EAST],AUTHORITY["EPSG",4326]]
# An unexpected error has been detected by HotSpot Virtual Machine:
#  SIGSEGV (0xb) at pc=0xb78475ff, pid=24875, tid=3085108928
# Java VM: Java HotSpot(TM) Client VM (1.5.0-b64 mixed mode)
# Problematic frame:
# V  [libjvm.so+0x1695ff]
# An error report file with more information is saved as hs_err_pid24875.log
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
Abort
Any hints?
The error log can be seen here
http://www.nabble.com/file/3845/hs_err_pid24875.log hs_err_pid24875.log
Carsten
View this message in context: http://www.nabble.com/swig-java-dumps-core-tf2507983.html#a6993229
Sent from the GDAL - Dev mailing list archive at Nabble.com.
