[Gdal-dev] swig/java dumps core
Collins, Benjamin collinsb at mitre.org
Wed Oct 25 12:04:51 EDT 2006
Carsten,
You are probably having problems with the retrieval of GCPs.  In order
to make the retrieval as natural as possible in Java, I put the results
in a Vector.  Since I have no files with GCPs sitting around to test
this approach on, it remains mostly untested.  I can take a look at
this problem if you have a sample that I can access.
Ben Collins
>-----Original Message-----
>From: gdal-dev-bounces at lists.maptools.org
>[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of oland
>Sent: Wednesday, October 25, 2006 10:33 AM
>To: gdal-dev at lists.maptools.org
>Subject: [Gdal-dev] swig/java dumps core
>Hello List
>I have built the swing/java bindings in gdal-1.3.2. When I try
>to run the
>gdalinfo java app it dumps core see below.
>java -cp .:../gdal.jar -Djava.library.path=../.libs/ gdalinfo
>/opt/Mapdata/BSB_ROOT/11006/11006_1.KAP
>Driver: BSB/Maptech BSB Nautical Charts
>Size is 10967, 9389
>Coordinate System is:
>Origin = (0.0,0.0)
>Pixel Size = (1.0,1.0)
>  0.0, 1.0, 0.0
>  0.0, 0.0, 1.0
>GCP Projection = GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>84",6378137,298.257223563,AUTHORITY["EPSG",7030]],TOWGS84[0,0,0
>,0,0,0,0],AUTHORITY["EPSG",6326]],PRIMEM["Greenwich",0,AUTHORIT
>Y["EPSG",8901]],UNIT["degree",0.0174532925199433,AUTHORITY["EPS
>G",9108]],AXIS["Lat",NORTH],AXIS["Long",EAST],AUTHORITY["EPSG",4326]]
># An unexpected error has been detected by HotSpot Virtual Machine:
>#  SIGSEGV (0xb) at pc=0xb78475ff, pid=24875, tid=3085108928
># Java VM: Java HotSpot(TM) Client VM (1.5.0-b64 mixed mode)
># Problematic frame:
># V  [libjvm.so+0x1695ff]
># An error report file with more information is saved as
>hs_err_pid24875.log
># If you would like to submit a bug report, please visit:
>#   http://java.sun.com/webapps/bugreport/crash.jsp
>Abort
>Any hints?
>The error log can be seen here
>http://www.nabble.com/file/3845/hs_err_pid24875.log
>hs_err_pid24875.log
>Carsten
>View this message in context:
>http://www.nabble.com/swig-java-dumps-core-tf2507983.html#a6993229
>Sent from the GDAL - Dev mailing list archive at Nabble.com.
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
