[Gdal-dev] GDAL 1.3.2 SWIG C# Bindings?
Tamas Szekeres szekerest at gmail.com
Wed Oct 25 16:15:48 EDT 2006
I would encourage you to use the latest CVS version. There were some fundamental
changes since 1.3.2 to make the things work.
You might run into the same issue described at:
http://bugzilla.remotesensing.org/show_bug.cgi?id=949
Some parts of the GDAL C# is still incomplete, I hope we can get them
work for the next release.
Best Regards,
Tamas Szekeres
2006/10/25, Marc Lepage <mlepage at pyxisinnovation.com>:
> Hi all.
> I've tried to build the gdal-1.3.2 SWIG bindings for csharp, which generate,
> but fail on C# compilation as noted below.
> Basically, I think SpatialReference is put in the OSR namespace, but not
> scoped (and therefore inaccessible) from the OGR namespace. I don't see
> anything in the SWIG interface files or makefiles that would make this work,
> but admittedly I'm a SWIG newbie. (Actually, I was rather hoping to do
> something similar with namespaces in another project I am wrapping with
> SWIG, and therefore curious as to how GDAL accomplished this.)
> Should this work? Or am I doing something wrong? Thanks.
> csc /debug:full /target:library /out:gdal_ogr_csharp.dll ogr\*.cs
> Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42
> for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727
> Copyright (C) Microsoft Corporation 2001-2005. All rights reserved.
> ogr\DataSource.cs(78,41): error CS0246: The type or namespace name
>         'SpatialReference' could not be found (are you missing a using
> directive
>         or an assembly reference?)
> ogr\Geometry.cs(219,26): error CS0246: The type or namespace name
> directive
> ogr\Geometry.cs(224,24): error CS0246: The type or namespace name
>         'CoordinateTransformation' could not be found (are you missing a
> using
>         directive or an assembly reference?)
> ogr\Geometry.cs(229,10): error CS0246: The type or namespace name
> directive
> ogr\Geometry.cs(235,38): error CS0246: The type or namespace name
> directive
> ogr\Layer.cs(147,10): error CS0246: The type or namespace name
> directive
> ogr\ogr.cs(15,57): error CS0246: The type or namespace name
> 'SpatialReference'
>         could not be found (are you missing a using directive or an assembly
>         reference?)
> ogr\ogr.cs(21,71): error CS0246: The type or namespace name
> 'SpatialReference'
>         reference?)
> NMAKE : fatal error U1077:
> 'C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.EX
> E' : return code '0x1'
> Stop.
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> 8\VC\BIN\n
> make.EXE"' : return code '0x2'
> Stop.
> Marc Lepage
> the PYXIS innovation - common ground for digital earth
> www.pyxisinnovation.com
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
