[Gdal-dev] SDE Driver Change
    Frank Warmerdam
    warmerdam at pobox.com
    Thu Oct 26 14:15:02 EDT 2006
Christian Ratliff wrote:
>   During the QA process for our product, we noticed polygons were being
> read from ARC/SDE with a reversed (left hand) winding.  This results in
> isClockwise() returning the wrong value for all such polygons.  I
> updated the SDE driver with the change indicated below and then
> re-tested SDE and non-SDE data sources.  Everything looks good now:
> src/ogr/ogrsf_formats/sde/ogrsdelayer.cpp
> 719c723
> <     nSDEErr = SE_shape_get_all_points( hShape, SE_DEFAULT_ROTATION,
>>     nSDEErr = SE_shape_get_all_points( hShape, SE_RIGHT_HAND_ROTATION,
Christian,
There is no harm in doing this, but I would note that OGRPolygon rings
are not guaranteed to have any particular handedness.  So it is unwise
to build application on this assumption.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
