[Gdal-dev] RFC 3: GDAL Commiter Guildlines
Daniel Morissette dmorissette at mapgears.com
Fri Oct 27 14:40:04 EDT 2006
Frank Warmerdam wrote:
> The cost is the extra complication in the CVS history - ie. the log
> command gets much more complicated and less comprehensible.
True. The cvs logs are globally polluted by the log messages of all
branches. Glad to hear this is fixed in SVN.
> Normally one does not pull down the full repository, just one branch or
> the trunk.  In this case the branches don't take extra traffic.
I have to admit I don't know SVN much, I had just assumed from what I
read that the default behavior was to pull all branches unless you
specify a single branch or the trunk at checkout time. If the default is
to only pull the trunk (like CVS does) then you're right that solves
this issue.
Thanks for the clarifications
Daniel
Daniel Morissette
http://www.mapgears.com/
