[Gdal-dev] how to "for each poly do X" ?
matt wilkie maphew at gmail.com
Sun Oct 29 02:49:56 EST 2006
Hi All, this is likely a little offtopic for this list, or at least off the
beaten path, but the folks who hang out here are likely to know where to
point me... I'm working on a project processing a lot of landsat7 and other
images and tile-management is so far the hardest part I've tackled. I need
to break things into pieces, do some work on them, and then reassemble them
and stuff them somewhere else, largely unattended.
Under ArcInfo I'd use AML and cursors: basically for each polygon in an
index cover do X,Y and Z. I'm at a loss so far to how to do the same thing
with the open source tools I have. Namely fwtools, qgis and ossim (all on
windows). Where do I begin?  I imagine this to be common scenario, how
are/have other people handled it?
thanks in advance for your thoughts,
-matt
View this message in context: http://www.nabble.com/how-to-%22for-each-poly-do-X%22---tf2533494.html#a7058496
Sent from the GDAL - Dev mailing list archive at Nabble.com.
