[Gdal-dev] Converting DTED to image file format
jim hopper JAMES.E.HOPPER at saic.com
Sun Oct 29 15:28:35 EST 2006
Frank,
If you merge dted like you show below what is the pixel type (float or
integer)?
Thanks jim
On 10/29/06 12:00 PM, "gdal-dev-request at lists.maptools.org"
<gdal-dev-request at lists.maptools.org> wrote:
> There are two GDAL commands for merging many files.  The gdal_merge.py
> Python script, and in GDAL 1.3.2 and later you can use gdalwarp.
> You might try something like:
>    gdalwarp abc/*.dt0 mosaic.tif
