[Gdal-dev] RFC 7: API Change for the VSIxxxL family of file functions
Eric Dönges eric.doenges at gmx.net
Mon Oct 30 14:03:34 EST 2006
Hi list,
in response to my gripe about VSIOpenL claiming to return a FILE*
when it's not,
Frank said I should submit an RFC, so here it is.
--- snip ---
Author: Eric Dönges
Contact: Eric.Doenges at gmx.net
Status: Proposed
Purpose
To change the API for the VSIxxxL family of functions to use a new
data-type
VSILFILE* instead of the current FILE*.
Background, Rationale
Currently, GDAL offers two APIs to abstract file access functions
(referred to
as VSIxxx and VSIxxxL in this document). Both APIs claim to operate
on FILE*;
however, the VSIxxxL functions can only operate on FILE* created by the
VSIOpenL function. This is because VSIOpenL returns a pointer to an
internal
C++ class typecast to FILE*, not an actual FILE*. This makes it
impossible
for the compiler to warn when the VSIxxx and VSIxxxL functions are
inappropriately mixed.
Proposed Fix
A new opaque data-type VSILFILE* shall be declared. All VSIxxxL
functions shall
be changed to use this new type instead of FILE*. Additionally, any
GDAL code
that uses the VSIxxxL functions must be changed to use this data-type
as well.
Implementation Details
While it would seem natural to declare VSILFILE* as a typedef of a
void pointer
similar to the way GDAL defines the data-type handles for the C API,
this has
the disadvantage that the compiler will not be able to warn about
improper
pointer conversions since any type of pointer can be converted to a void
pointer. Instead, it is proposed to declare VSIFILE with the help of
an empty
forward declaration, i.e. "typedef struct VSILFILE VSILFILE", with
the struct
VSILFILE left undefined.
--- snip ---
The necessary changes should be very simple, if a lot of busywork. As
as I said in my
initial post, I volunteer to do the required work. (However, I can
only test on
MacOS or Linux).
With kind regards,
Eric
