[Gdal-dev] GDALDataset as a Base Class
Mateusz Loskot mateusz at loskot.net
Fri Sep 1 16:10:14 EDT 2006
Matt Hanson wrote:
> Well I'm glad to see my post started a discussion about these things
> but I don't have much to add because I'm having a hard time following
> some of it.
It's more a kind of academic debate. It does not apply directly to your
problem, so don't worry ;-)
> I'm creating an Geospatial Image Processing
> library.   The underlying dataset resides on disk and is interfaced
> through GDAL, and is read and processed in chunks, and written out.
> My goal is to make the file I/O and chunking process as transparent
> as possible to the developer.
Does the 'transparent' mean you don't want to make user of your
library to deal directly with GDAL?
So, user needs only to pass filename/dataset location to your interface
and GDAL objects are create behind the scene?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
