[Gdal-dev] importFromWkt() problem
Sat Sep 2 13:01:32 EDT 2006
Petteri Packalen wrote:
> WKT_BUF 1000000
> char * geo_trans = new char[ WKT_BUF ];
> The code is too length and fragmentd to be pasted here as a whole. The
> latter approch creates correct output. However, now I noticed that there
> may have some memory de-allocation problem with it which lead to another
> question. Because I use SetGeometryDirectly( new_geom ), I don't release
> new_geom explicitly. I have understood OGRFeature::DestroyFeature(
> poDstFeature ) de-allocates it and all other resources it uses. Have I
> understood it correctly?
Petteri,
Yes, that is correct.  You should not need to do anything to deallocate
the geometry after using SetGeometryDirectly().
How do you deallocate geo_trans though?  You can't use delete on the
geo_trans pointer after passing it to ImportFromWkt() since the pointer
is changed by that function.  I suspect this is your problem.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
