[Gdal-dev] python gdal 1.3.2 and geos
Didrik Pinte dpinte at itae.be
Wed Sep 6 03:23:57 EDT 2006
Le mardi 05 septembre 2006 à 09:38 -0700, Christopher Barker a écrit :
> Didrik Pinte wrote:
> > Because of a problem between gdalnumeric and python-numpy, I have
> > uninstalled the following packages and kept only python-numeric :
> > apt-get remove python-numpy python-numpy-ext python-scipy fftw3
> > It solved the problem ! That's strange.
> That is very odd. the new numpy and the old Numeric should have no
> trouble at all co-existing.
That's why i was running with both of them.
> My guess is that it is a Debian bug -- perhaps the python-numpy package
> is set up to replace Numeric, rather than coexist with it. However, if
> not, then there may be a bug in numpy, and it should be reported. It is
> certainly intended that they don't interfere with one another.
Running my application on windows and linux, it seems that the windows
version is running with numpy and Numeric without the problems
encountered on the Debian installation. I will investigate a bit the
problem on the Debian system.
Didrik
