[Gdal-dev] GML file problems
Dan Putler putler at sauder.ubc.ca
Fri Sep 8 19:13:13 EDT 2006
Hi All,
I'm attempting to use ogr2ogr for the purposes of converting a file
encoded in GML2.1.2 to a shapefile, but ogr2ogr is not recognizing it
as a GML file. I'm using the version of gdal/ogr bundled with FWTools
1.0.5.
Here is the GML file I'm trying to use as a source:
<?xml version="1.0" encoding="utf-8" standalone="no"?>
<PostalCodeLookup version="1.0.0" xmlns:xsi="http://www.w3.org/2001/
XMLSchema-instance" xsi:noNamespaceSchemaLocation="http://cgdi-
dev.geoconnections.org/prototypes/schemas/cgdi/postalcode/1.0.0/
postalcode.xsd" xmlns:gml="http://www.opengis.net/gml">
	<gml:boundedBy>
		<gml:Null>inapplicable</gml:Null>
	</gml:boundedBy>
	<PostalCodeResultSet sortArea="FSA">
		<PostalCode>
			<gml:name>V1A</gml:name>
			<Placename>Kimberley</Placename>
			<ProvinceOrTerritory>BC</ProvinceOrTerritory>
			<gml:centerOf>
				<gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
					<gml:coordinates>-115.970116,49.660305</gml:coordinates>
				</gml:Point>
			</gml:centerOf>
		</PostalCode>
	</PostalCodeResultSet>
</PostalCodeLookup>
Dan
