[Gdal-dev] Creating VRT datasets
Fri Sep 8 23:00:31 EDT 2006
On 9/8/06, Matt Hanson <mhanson at photon.com> wrote:
> I'm having problems programatically creating VRT datasets.
Matt,
This is a bug in the VRT "create from metadata" logic.
It works for calls via SetMetadata(), but not via
SetMetadataItem().  I found that the following slight
variation does work.
I will try and fix this in the code tonight as well,
but for the time being you will need to workaround
it by going through SetMetadata().
Best regards,
