[Gdal-dev] Re: joining DBFs
Neil Best nbest at speakeasy.net
Mon Sep 11 11:28:19 EDT 2006
Something is going wrong.  I have created indexes on both tables even
though it wasn't clear if that is strictly necessary for the primary
table.  Having an unknown SRS wouldn't cause this, would it?  I should
just look up my EPSG -- that's what I'll do next.  It appears to do
something before seg-faulting -- maybe there is a corrupt polygon?
I see that the key of the secondary table also gets added as a column,
which Arc also does in a join operation.  I find this unnecessary and
annoying.  Is there an argument in favor?  I guess it can be dropped
easily enough, but notice that DBF truncates that qualified column name.
Also, there appears to be a problem with the -overwrite option that I
show at the end of my output that I don't understand, requiring an rm
step.  Is this a limitation of the SHP driver or something I am doing wrong?
I thought better of attaching my data.  Drop me a line if you would like
to have a look at it.  Thanks for any insight.
neil at gandalf:~/gis/kb$ ogr2ogr -sql "SELECT * FROM mpo2 LEFT JOIN
2000HH_poverty_UNIVERSAL ON
geo_identi=2000HH_poverty_UNIVERSAL.geo_identi" -nln mpo2_poverty test ses
Segmentation fault
neil at gandalf:~/gis/kb$ ogrinfo test mpo2_poverty INFO: Open of `test'
using driver `ESRI Shapefile' successful.
Layer name: mpo2_poverty
Geometry: Polygon
Feature Count: 0
Extent: (0.000000, 0.000000) - (0.000000, 0.000000)
Layer SRS WKT:
(unknown)
SHAPECODE: String (16.0)
ZONE_AREA: Real (16.0)
OID_: Integer (9.0)
GEO_IDENTI: String (14.0)
TOTPOP: Real (10.2)
ONE_RACE: Real (10.2)
WHITE: Real (10.2)
BLACK: Real (10.2)
AMERINDIAN: Real (10.2)
ASIAN: Real (10.2)
PACIFIC: Real (10.2)
OTHER: Real (10.2)
TWO_PLUS_R: Real (10.2)
HISPANIC: Real (10.2)
NOT_HISPAN: Real (10.2)
NHISP_WHIT: Real (10.2)
2000HH_pov: String (14.0)
HOUSEHOLDS: Real (8.2)
HOUSEHOL_A: Real (8.2)
neil at gandalf:~/gis/kb$ ls test
mpo2_poverty.dbf  mpo2_poverty.shp  mpo2_poverty.shx
neil at gandalf:~/gis/kb$ ogrinfo -sql "SELECT * FROM mpo2 LEFT JOIN
geo_identi=2000HH_poverty_UNIVERSAL.geo_identi" ses INFO: Open of `ses'
Layer name: mpo2
Geometry: Polygon
Feature Count: 17466
Extent: (211950.731904, 1576286.159537) - (885960.120408, 2252334.267779)
Layer SRS WKT:
(unknown)
OID_: Integer (9.0)
TOTPOP: Real (10.2)
WHITE: Real (10.2)
BLACK: Real (10.2)
ASIAN: Real (10.2)
OTHER: Real (10.2)
2000HH_poverty_UNIVERSAL.GEO_IDENTI: String (14.0)
OGRFeature(mpo2):0
    SHAPECODE (String) = 4610051
    ZONE_AREA (Real) =           415737
    OID_ (Integer) = 17100
    GEO_IDENTI (String) = 4610051
    TOTPOP (Real) =      26.73
    ONE_RACE (Real) =      26.73
    WHITE (Real) =      26.34
    BLACK (Real) =       0.10
    AMERINDIAN (Real) =       0.00
    ASIAN (Real) =       0.29
    PACIFIC (Real) =       0.00
    OTHER (Real) =       0.00
    TWO_PLUS_R (Real) =       0.00
    HISPANIC (Real) =       0.00
    NOT_HISPAN (Real) =      26.73
    NHISP_WHIT (Real) =      26.34
    2000HH_poverty_UNIVERSAL.GEO_IDENTI (String) = 4610051
    HOUSEHOLDS (Real) =     8.75
    HOUSEHOL_A (Real) =     0.42
    POLYGON ((565168.49996185512282
2123297.036226258147508,567837.380521122599021
2123311.42119784001261,567836.905601977137849
2123150.250083384104073,567836.875 2123150.25,566502.812442400609143
2123148.437627284321934,565168.658338983776048
2123146.625130200758576,565168.49996185512282 2123297.036226258147508))
OGRFeature(mpo2):1
    SHAPECODE (String) = 4610042
    ZONE_AREA (Real) =           405230
    OID_ (Integer) = 17097
    GEO_IDENTI (String) = 4610042
    TOTPOP (Real) =      12.42
    ONE_RACE (Real) =      12.42
    WHITE (Real) =      12.30
    BLACK (Real) =       0.00
    ASIAN (Real) =       0.11
    OTHER (Real) =       0.00
    NOT_HISPAN (Real) =      12.42
    NHISP_WHIT (Real) =      12.30
    2000HH_poverty_UNIVERSAL.GEO_IDENTI (String) = 4610042
    HOUSEHOLDS (Real) =     6.87
    HOUSEHOL_A (Real) =     0.33
    POLYGON ((567837.380521122599021
2123311.42119784001261,570497.874934128252789
2123300.937598436605185,570497.723520182771608
2123157.500268447212875,569167.374749097623862
2123153.875339915510267,567836.905601977137849
2123150.250083384104073,567837.380521122599021 2123311.42119784001261))
OGRFeature(mpo2):2
    SHAPECODE (String) = 4610041
    ZONE_AREA (Real) =           358029
    OID_ (Integer) = 17096
    GEO_IDENTI (String) = 4610041
    TOTPOP (Real) =       0.48
    ONE_RACE (Real) =       0.48
    WHITE (Real) =       0.48
    BLACK (Real) =       0.00
    ASIAN (Real) =       0.00
    OTHER (Real) =       0.00
    NOT_HISPAN (Real) =       0.48
    NHISP_WHIT (Real) =       0.48
    2000HH_poverty_UNIVERSAL.GEO_IDENTI (String) = 4610041
    HOUSEHOLDS (Real) =     5.00
    HOUSEHOL_A (Real) =     0.24
    POLYGON ((570497.874934128252789
2123300.937598436605185,573158.271560193505138
2123290.454384359996766,573158.381680462392978
2123164.750001248437911,573158.375 2123164.75,571828.062485220958479
2123161.125170259270817,570497.723520182771608
2123157.500268447212875,570497.874934128252789 2123300.937598436605185))
OGRFeature(mpo2):3
    SHAPECODE (String) = 4610052
    ZONE_AREA (Real) =           387044
    OID_ (Integer) = 17101
    GEO_IDENTI (String) = 4610052
    TOTPOP (Real) =      12.21
    ONE_RACE (Real) =      12.21
    WHITE (Real) =      12.06
    BLACK (Real) =       0.14
    ASIAN (Real) =       0.02
    OTHER (Real) =       0.00
    HISPANIC (Real) =       0.21
    NOT_HISPAN (Real) =      12.00
    NHISP_WHIT (Real) =      11.84
    2000HH_poverty_UNIVERSAL.GEO_IDENTI (String) = 4610052
    HOUSEHOLDS (Real) =    11.30
    HOUSEHOL_A (Real) =     0.67
    POLYGON ((562499.551199327223003
2123282.650887067895383,565168.49996185512282
2123297.036226258147508,565168.658338983776048
2123146.625130200758576,563834.437308961409144
2123144.812542194500566,562500.262920987908728
2123143.000017553567886,562499.551199327223003 2123282.650887067895383))
OGRFeature(mpo2):4
    SHAPECODE (String) = 4610032
    ZONE_AREA (Real) =           301133
    OID_ (Integer) = 17093
    GEO_IDENTI (String) = 4610032
    TOTPOP (Real) =       0.56
    ONE_RACE (Real) =       0.56
    WHITE (Real) =       0.56
    BLACK (Real) =       0.00
    ASIAN (Real) =       0.00
    OTHER (Real) =       0.00
    NOT_HISPAN (Real) =       0.56
    NHISP_WHIT (Real) =       0.56
    2000HH_poverty_UNIVERSAL.GEO_IDENTI (String) = 4610032
    HOUSEHOLDS (Real) =     0.47
    HOUSEHOL_A (Real) =     0.04
    POLYGON ((573158.271560193505138
2123290.454384359996766,575833.499946153140627
2123264.680594602134079,575833.422804853646085
2123165.249997253529727,574495.937499998952262
2123165.000005841255188,573158.381680462392978
2123164.750001248437911,573158.271560193505138 2123290.454384359996766))
OGRFeature(mpo2):5
    SHAPECODE (String) = 4610061
    ZONE_AREA (Real) =           373248
    OID_ (Integer) = 17104
    GEO_IDENTI (String) = 4610061
    TOTPOP (Real) =       3.76
    ONE_RACE (Real) =       3.70
    WHITE (Real) =       3.59
    BLACK (Real) =       0.01
    ASIAN (Real) =       0.04
    OTHER (Real) =       0.06
    TWO_PLUS_R (Real) =       0.06
    HISPANIC (Real) =       0.12
    NOT_HISPAN (Real) =       3.64
    NHISP_WHIT (Real) =       3.53
    2000HH_poverty_UNIVERSAL.GEO_IDENTI (String) = 4610061
    HOUSEHOLDS (Real) =    12.52
    HOUSEHOL_A (Real) =     0.80
    POLYGON ((559860.124304226133972
2123272.137048966716975,562499.551199327223003
2123282.650887067895383,562500.262920987908728
2123143.000017553567886,562500.25 2123143.0,561180.563844703836367
2123135.984603217802942,559860.851143212290481
2123128.969065317418426,559860.124304226133972 2123272.137048966716975))
OGRFeature(mpo2):6
    SHAPECODE (String) = 4610062
    ZONE_AREA (Real) =           387825
    OID_ (Integer) = 17105
    GEO_IDENTI (String) = 4610062
    TOTPOP (Real) =       3.46
    ONE_RACE (Real) =       3.46
    WHITE (Real) =       3.46
    BLACK (Real) =       0.00
    ASIAN (Real) =       0.00
    OTHER (Real) =       0.00
    NOT_HISPAN (Real) =       3.46
    NHISP_WHIT (Real) =       3.46
    2000HH_poverty_UNIVERSAL.GEO_IDENTI (String) = 4610062
    HOUSEHOLDS (Real) =     5.65
    HOUSEHOL_A (Real) =     0.19
    POLYGON ((557183.877244946546853
2123261.476542191114277,559860.124304226133972
2123272.137048966716975,559860.851143212290481
2123128.969065317418426,558541.187734182458371
2123121.953789453487843,557186.092565013910644
2123114.75015982426703,557185.866814971901476
2123129.702169452793896,557183.877244946546853 2123261.476542191114277))
OGRFeature(mpo2):7
    SHAPECODE (String) = 4610031
    ZONE_AREA (Real) =           230844
    OID_ (Integer) = 17092
    GEO_IDENTI (String) = 4610031
    TOTPOP (Real) =       0.07
    ONE_RACE (Real) =       0.07
    WHITE (Real) =       0.07
    BLACK (Real) =       0.00
    ASIAN (Real) =       0.00
    OTHER (Real) =       0.00
    NOT_HISPAN (Real) =       0.07
    NHISP_WHIT (Real) =       0.07
    2000HH_poverty_UNIVERSAL.GEO_IDENTI (String) = 4610031
    HOUSEHOLDS (Real) =     0.07
    HOUSEHOL_A (Real) =     0.01
    POLYGON ((575833.499946153140627
2123264.680594602134079,578508.610308142262511
2123238.907941915560514,578508.432067663408816
2123165.749987302813679,577170.9375 2123165.5,575833.422804853646085
2123165.249997253529727,575833.499946153140627 2123264.680594602134079))
OGRFeature(mpo2):8
    SHAPECODE (String) = 4609011
    ZONE_AREA (Real) =           229076
    OID_ (Integer) = 16955
    GEO_IDENTI (String) = 4609011
    TOTPOP (Real) =       6.63
    ONE_RACE (Real) =       6.44
    WHITE (Real) =       6.36
    BLACK (Real) =       0.02
    ASIAN (Real) =       0.00
    OTHER (Real) =       0.06
    TWO_PLUS_R (Real) =       0.19
    HISPANIC (Real) =       0.04
    NOT_HISPAN (Real) =       6.59
    NHISP_WHIT (Real) =       6.34
    2000HH_poverty_UNIVERSAL.GEO_IDENTI (String) = 4609011
    HOUSEHOLDS (Real) =     2.55
    HOUSEHOL_A (Real) =     0.15
    POLYGON ((554590.91588362515904
2123241.632391711231321,557183.877244946546853
2123261.476542191114277,557185.866814971901476
2123129.702169452793896,555888.410371425678022
2123163.290501976385713,554584.285233602509834
2123197.051472527906299,554590.91588362515904 2123241.632391711231321))
OGRFeature(mpo2):9
    SHAPECODE (String) = 4609014
    ZONE_AREA (Real) =          6951748
    OID_ (Integer) = 16957
    GEO_IDENTI (String) = 4609014
    TOTPOP (Real) =     155.95
    ONE_RACE (Real) =     152.29
    WHITE (Real) =     150.60
    BLACK (Real) =       0.42
    ASIAN (Real) =       0.00
    OTHER (Real) =       1.27
    TWO_PLUS_R (Real) =       3.66
    HISPANIC (Real) =       1.66
    NOT_HISPAN (Real) =     154.29
    NHISP_WHIT (Real) =     150.18
    2000HH_poverty_UNIVERSAL.GEO_IDENTI (String) = 4609014
    HOUSEHOLDS (Real) =    66.53
    HOUSEHOL_A (Real) =     5.12
    POLYGON ((551953.502148762461729
2123221.448043493088335,554590.91588362515904
2123241.632391711231321,554584.285233602509834
2123197.051472527906299,554600.954803448054008
2121870.175678761675954,554617.624373293714598
2120543.29988499591127,553313.499235470429994
2120577.060855546966195,552009.364189005456865
2120610.822082611266524,551980.995648902608082
2121936.581881972495466,551980.965271481196396
2121938.001523731742054,551953.502148762461729 2123221.448043493088335))
Segmentation fault
FAILED: Layer mpo2_poverty already exists, and -append not specified.
          Consider using -append, or -overwrite.
ERROR 1: Terminating translation prematurely after failed
translation from sql statement.
neil at gandalf:~/gis/kb$ ogr2ogr -overwrite -sql "SELECT * FROM mpo2 LEFT
JOIN 2000HH_poverty_UNIVERSAL ON
ERROR 6: DeleteLayer() not supported by this data source.
DeleteLayer() failed when overwrite requested.
Neil Best wrote:
> Sorry, I just looked at the OGR SQL page again for the first time in a
> while.  Is the JOIN support new?  Maybe I just conflated the GRASS and
> OGR SQL features.  This looks like it will do the trick.  As penance I
> will submit my query as an example.
> Neil
> Neil Best wrote:
>> Can someone point me to a straightforward way to join attributes from
>> an   additional dbf table using either OGR or GRASS, or even Perl?
>> It's so easy in Arc that I would think this has been solved in our
>> world also.  So far my impression is that I would have to script a
>> row-by-row UPDATE since the SQL drivers don't support any type of JOIN
>> afaik.  It seems like I have seen an example somewhere using a Perl
>> DBF module but I can't put my finger on it.  I'll keep digging and
>> hopefully this wheel has been invented.
>> Neil
