[Gdal-dev] MSVCRT80.dll
Simon Perkins sy at perkins.net
Tue Sep 12 12:27:15 EDT 2006
With the stricter checking for DLL compatibility in Visual Studio, I've
found that it now matters a lot more whether things were compiled with
the debug or non debug version of the runtime library, i.e. /MD vs /MDd.
So you'd better make sure you're using the smae runtime libraries for
everything, including your application, GDAL, and any of the DLLs that
GDAL depends upon if you built those separately. i.e. you might find you
have to build two different versions of GDAL, one for debug and one for
release. In earlier versions you seemed to be able to get away with this
more.
At least, this is the conclusion I came to a while back ad it seems to
be working, but to be honest, I don't fully understand all the  manifest
/ DLL issues in VS 2005 ad it seems poorly explained in the docs.
Cheers,
Sy
Matt Hanson wrote:
> I have Visual Studio 2005 Prof, so I'm not sure what this redistributable package would add.
> I've been using GDAL fine in my app, but then I tried to upgrade to the latest version and this problem cropped up again, trying to go back to the stable version results in the same problem.   ack
> ________________________________
> From: Ned Harding [mailto:nharding at extendthereach.com]
> Sent: Mon 9/11/2006 10:48 PM
> To: Matt Hanson; Gdal-dev at lists.maptools.org
> Subject: RE: [Gdal-dev] MSVCRT80.dll
> MS changed the way the dlls install for VS2005.  The easiest way to deal
> with it is to just use their install to make sure they are all in the
> right places.
> http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=
> 32BC1BEE-A3F9-4C13-9C99-220B62A191EE
> Ned.
> -----Original Message-----
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Matt Hanson
> Sent: Monday, September 11, 2006 8:33 PM
> To: Gdal-dev at lists.maptools.org
> Subject: [Gdal-dev] MSVCRT80.dll
> I'm not sure how exactly I did things differently, but I got the latest
> snapshot for the SetMetadataItem fix and compiled using nmake as per the
> Windows install directions.   I overwrote my gdal13.dll and
> gdal13.dll.manifest files and I'm getting a error:
> "This application has failed to start because MSVCR80.dll was not found.
> Re-installing the application may fix the problem"
> I'm using nmake.opt as is except for changing the directory.   I also
> edited cpl_config.h.vc to set the vnsprintf and related functions to 0.
> Now it's important to note that I did get this error when I first tried
> to install GDAL but ended up solving it by copying the dll and manifest
> files to the directory where my exe is located.   But this time it
> doesn't work.  I even went back to the 1.3.2 release version and am
> getting the same error.   Also note I have followed all old suggestions
> on the forums concerning this and they don't work.  This is somehow
> related to debug information.
> Has anyone else encountered this?   This problem drove me nuts for hours
> the first time and I'd rather not repeat it.
> Gdal-dev mailing list
> http://lists.maptools.org/mailman/listinfo/gdal-dev
