[Gdal-dev] ogr2ogr: Command not found.
Ryan Ollerenshaw ollerery at engr.orst.edu
Thu Sep 14 17:20:51 EDT 2006
So i had to recompile gdal from the source in order to add support for
Xerces-C but after i did this i was still getting the same error so i
removed ogr2ogr from the /usr/local/bin/ directory and then recompiled
gdal again but now the ogr2ogr command is not being put back into the
/usr/local/bin/ directory.  what do i need to do in order to get the
gdal command back in there.
Thank you,
-Ryan
