[Gdal-dev] Gdal_translate and the Internal accuracy of ground control points
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Mon Sep 18 05:36:52 EDT 2006
I have inserted ground control points into a GeoTIFF image file with gdal_translate in this way:
gdal_translate input.tif  output_gcp.tif -gcp 0 0  285113.632 6713217.584 etc.
Gdalinfo reports me about the resulting image as follows:
GCP Projection =
GCP[  0]: Id=1, Info=
          (0,0) -> (285114,6.71322e+006,0)
Are the gcp's still stored into the GeoTIFF file with the same accuracy I gave them, or are they rounded like gdalinfo is expressing them?
Regards,
-Jukka Rahkonen-
