[Gdal-dev] gdal 1.3.1 install
Ryan Ollerenshaw ollerery at engr.orst.edu
Mon Sep 18 13:45:49 EDT 2006
I am trying to compile gdal on fedora core 5 but i keep running into
problems, i am using the following configure command:
./configure  --with-png  --with-libtiff  --with-jpeg  --with-gif
--with-geotiff=internal --with-pg=/usr/local/pgsql/bin/pg_config
--with-geos --without-cfitsio
then during make i am getting the following error:
make[2]: Entering directory `/root/gdal-1.3.1/frmts/fit'
/bin/sh ../../libtool --mode=compile g++ -Wall  -O2   -I../../port
-I../../gcore -I../../alg -I../../ogr -I../../ogr/ogrsf_frmts
-I../../port  -c -o ../o/fitdataset.o fitdataset.cpp
 g++ -Wall -O2 -I../../port -I../../gcore -I../../alg -I../../ogr
-I../../ogr/ogrsf_frmts -I../../port -c fitdataset.cpp  -fPIC -DPIC -o
../o/.libs/fitdataset.o
fitdataset.cpp:177: error: extra qualification 'FITRasterBand::' on
member 'FITRasterBand'
fitdataset.cpp: In static member function 'static GDALDataset*
FITDataset::Open(GDALOpenInfo*)':
fitdataset.cpp:1019: warning: dereferencing type-punned pointer will
break strict-aliasing rules
make[2]: *** [../o/fitdataset.o] Error 1
make[2]: Leaving directory `/root/gdal-1.3.1/frmts/fit'
make[1]: *** [fit-install-obj] Error 2
make[1]: Leaving directory `/root/gdal-1.3.1/frmts'
make: *** [frmts-target] Error 2
any help would be great, thanks.
