[Gdal-dev] RFC DRAFT: Unicode support in GDAL
Mateusz Loskot mateusz at loskot.net
Thu Sep 21 17:51:44 EDT 2006
Armin Burger wrote:
> When I remeber well, you have to specify globally in the Windows
> registry if the .dbf of shapefiles are encoded in UTF. But if you do
> so and then load a shapefile not in UTF then the special characters
> are displayed wrong.
> So ArcGIS has not really a flexible support for UTF, at least not for
>  shapes.
Yes, you're right, although this setting applies to ArcGIS behavior.
AFAIU, it's something like turn on/off Unicode support :-)
If we want to work out more flexible solution we need to know what's the
data encoding itself, because in fact we will deal with 3 encodings:
local on user's computer, UTF-8 used by GDAL and dataset encoding.
IOW, we need to know how to read data and to convert it to UTF-8 in
order to push it to user through another conversion from UTF-8 to user's
locale. This is my understanding of the problem.
So, Shapefile's localization driver ID or .cpg file can be used here,
regarding OGR and Shapefile driver only, as an example.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
