[Gdal-dev] Problem with ogr2ogr and S-57 data
Fri Sep 22 03:15:43 EDT 2006
Holger Läbe wrote:
> Hi,
> i'm trying to convert a S-57 inland enc cell to ESRI Shapefile. The
> railways and roads however are'nt correctly converted.
> It seems as there are multiple, disjunct segements in one geometry
> object, but this is misinterpreted(?) by ogr2ogr. They are placed as one
> polyline with connections across the enc cell area.
Holger,
I would appreciate it if you could file a bug with an S-57 file
demonstrating the problem, and specific details (such as the feature id
and layer) I can use to isolate a feature with the problem.
Once I can reproduce it, I may be able to fix it.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
