[Gdal-dev] Warping GOES products
    Elan Feingold
    elan at bluemandrill.com
    Wed Sep 27 15:35:50 EDT 2006
I'm trying to use gdalwarp to convert GOES products (see
http://www.weather.gov/noaaport/html/icdtb48e.html), specifically the
GOES East and GOES West products, to Plate Caree, and I'm not having
much luck.
This is the workflow I've been following:
1) Convert the product into a raw grayscale file with the ucsat utility.
2) Convert the raw grayscale file into a TIFF using Imagemagick
3) Add 4 GCPs using gdal_translate
4) Use gdalwarp like this: gdalwarp -s_srs "+proj=lcc +lat_ts=25.000N
+lon_0=95.000W" -t_srs "+proj=eqc" TIGE02_new.2.tif
Unfortunately the resulting image, while definitely warped, doesn't
match up with our other Plate Caree maps.
Any ideas would be much appreciated!
Thanks,
-elan
