[Gdal-dev] Error reading ArcInfo Grid
Matthew Perry perrygeo at gmail.com
Wed Sep 27 23:28:44 EDT 2006
Frank,
On 9/27/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Matthew Perry wrote:
> > Trying to import an ArcInfo Grid into grass and I'm getting a bunch
> > of the following errors:
> > ERROR 1: IReadBlock failed at X offset 0, Y offset 5399
> > ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 5399
> I downloaded and tried this dataset and it seemed to work ok for me.
> Could you perhaps try it with FWTools 1.0.5?  I imagine it was a compression
> type that was fixed since the version of GDAL you are using.
> Looking through the code it seems like the last improvement in that code
> was in late 2005, so I presume GDAL 1.3.2 should work too.  Let me know
> if you see the problem with FWTools 1.0.5. Otherwise I think we can
> "write it off" as an already fixed problem.
Hrmmm. I'm using gdal 1.3.2 on our linux machine and fwtools 1.0.5 on
windows.. same error with both.
I'll try the latest cvs and see if that works...
Matthew T. Perry
GIS Analyst / Software Engineer
National Center for Ecological Analysis and Synthesis (NCEAS)
work: perry at nceas.ucsb.edu
web: http://www.perrygeo.net
