[Gdal-dev] Error reading ArcInfo Grid
Thu Sep 28 00:07:53 EDT 2006
Matthew Perry wrote:
> OK. My bad on this one. That grid works fine for me as well. It was in
> a directory with a bunch of other grids (all with the same problem)
> and I just used arc to copy one of them into its own directory for a
> smaller download. Apparently copying it solved the problem !
> I guess the lesson is that it's dangerous to keep all your grids in a
> single directory.. since they all share the info folder, the risk of
> corrupting them becomes high.
Matt,
GDAL should not be looking at the info directory at all.  If you can
capture just the grid directory for one problem grid, and not the info
directory I could dig into this further.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
