[Gdal-dev] Loosing positions in S-57 to S-57 conversion via ogr2ogr
Jean-Philippe RANNOU jean-philippe.rannou at ago.fr
Thu Sep 28 04:32:37 EDT 2006
I'm trying to use S-57 to S-57 conversion via OGR.
I set the minimum required options (specified in OGR S-57 html doc)
set OGR_S57_OPTIONS = "RETURN_PRIMITIVES=ON,RETURN_LINKAGES=ON,LNAM_REFS=ON"
I checked WRECKS positions in my S-57 file using
ogrinfo CA49995B.000 WRECKS
I did the conversion for WRECKS
ogr2ogr -skipfailure -append -f "S57" output.000 CA49995B.000 WRECKS
but in the resulting file when i check the resulting file
ogrinfo output.000 WRECKS
and the WRECKS positions disapeared (no more POINTS and empty polygons).
Has somebody experienced such conversion? What am i doing wrong?
Regards
   JP
RANNOU Jean-Philippe - ATLANTIDE
Consultant
Tel. : +33 (0)2 98 05 43 21
http://www.ago.fr/
Technopôle Brest Iroise
Site du Vernis - CS 23866
29238 Brest Cedex 3 - France
Fax. : +33 (0)2 98 05 20 34
e-mail: atlantide-brest at ago.fr
