[Gdal-dev] GDAL coordinate reference system retrieval problems.
Daniele Romagnoli dany.geotools at gmail.com
Fri Sep 29 09:17:28 EDT 2006
Dear Mr. Lucena,
Now I set this variable and it works fine.
Thank you very much.
Best Regards,
Daniele
On 9/29/06, Ivan Lucena <ILucena at clarku.edu> wrote:
>  Do you have GDAL_DATA environment variable set?
> *From:* gdal-dev-bounces at lists.maptools.org [mailto:
> gdal-dev-bounces at lists.maptools.org] *On Behalf Of *Daniele Romagnoli
> *Sent:* Friday, September 29, 2006 8:52 AM
> *To:* gdal-dev at lists.maptools.org; Frank Warmerdam; Simone Giannecchini
> *Subject:* [Gdal-dev] GDAL coordinate reference system retrieval problems.
> Hi list,
> I have some problems during coordinate reference system retrieval
> operations with GDAL.
> Using gdalinfo or directly using "Dataset.GetProjection()" on some files,
> it returns the empty string "" while,
> using gdalinfo from FWTools, it returns the required projection string.
> Any suggestion? (DLL, required library,...)?
> Best Regards,
> Daniele
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060929/3bd6d5af/attachment.html
