[Gdal-dev] Make error "libtool: compile: unable to infer tagged configuration"
Sun Apr 1 11:46:31 EDT 2007
Alessandro Amici wrote:
>>> $ svn checkout https://svn.osgeo.org/svn/gdal/trunk/gdal gdal
>>> svn: PROPFIND request failed on '/svn/gdal/gdal/!svn/vcc/default'
>>> svn: '/svn/gdal/gdal/!svn/vcc/default' path not found
>>>            ^^^^^^^^^ missing 'trunk'?
>> You need to relocate your working copy because you are using *old* URL
>> of the repository.
>> The new URL is:
>> https://svn.osgeo.org/gdal/
> that was a fresh checkout and the URL was cat'n'pasted from:
> http://www.gdal.org/download.html
> the page needs to be updated to reflect the new repository localtion.
Alessandro,
Fixed!
Thanks,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
