[Gdal-dev] HFA no data value support followup
Mon Apr 2 01:40:07 EDT 2007
Brian Claywell wrote:
> Frank et al,
> I spoke to you on #gdal the other day regarding my work implementing no
> data value support in the HFA driver, and I wanted to update you on my
> progress and doublecheck that what I was doing was acceptable.
> I've attached a (very rough!) diff which illustrates what I've done so
> far. Please keep in mind that I'm an electrical engineer by training and
> not a code wizard :) Without modifying any of the read routines, the
> statistics routines correctly honored the no-data value I set in a
> simple test case.
> Let me know if this approach is acceptable to you, and if there are any
> changes you'd like to see before I submit a cleaner version of the patch
> with some more error checking/handling and some streamlining.
Brian,
The approach looks ok from a quick skim.   When you are satisfied with what
you have submit it as a patch in the GDAL Trac, and I'll see about integrating
it in 1.5 (trunk).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
