[Gdal-dev] Make error "libtool: compile: unable to infer taggedconfiguration"
Patton, Eric epatton at nrcan.gc.ca
Mon Apr 2 10:36:21 EDT 2007
Hi, sorry for the delay in replying....I'll test the code you sent and
report back later today.
Regards,
Eric Patton
email: epatton at nrcan.gc.ca
> -----Original Message-----
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of
> Mateusz Loskot
> Sent: Sunday, April 01, 2007 7:36 AM
> To: gdal
> Subject: Re: [Gdal-dev] Make error "libtool: compile: unable
> Frank Warmerdam wrote:
> > Patton, Eric wrote:
> >> Hi,
> >> I just upgraded my Ubuntu to 7.04 Beta, and I'm re-compiling
> >> gdal-1.4.0. configure progresses cleanly with no obvious
> errors. At
> >> the very beginning of make, however, I encounter this error:
> >> $ sudo make
> >> (cd port; make)
> >> make[1]: Entering directory `/usr/local/gdal-1.4.0/port'
> >> /bin/sh /usr/local/gdal-1.4.0/libtool --mode=compile g++
> >> -DOGR_ENABLED -I/usr/local/gdal-1.4.0/port  -c -o cpl_conv.o
> >> cpl_conv.cpp
> >> libtool: compile: unable to infer tagged configuration
> >> libtool: compile: specify a tag with `--tag'
> >> make[1]: *** [cpl_conv.o] Error 1
> >> make[1]: Leaving directory `/usr/local/gdal-1.4.0/port'
> >> make: *** [port-target] Error 2
> >> Any ideas on what this error means and how to correct it?
> > Eric,
> > I'm afraid I don't know what causes this.  I'd appreciate it if you
> > could file a bug on this, and work with Mateusz to try and
> resolve it
> > before the
> > 1.4.1 release.
> AFAIK, this error means that libtool is can not determine
> what compiler is used exactly and libtool is confused.
> May be with newer version of libtool, it's works in more strict mode.
> As I remember, the solution is to explicitly distinct
> compiler tags for C and C++ compilation and specify them in
> configure/makefiles
> for C++ compilation it looks as:
> --tag CXX
> for C:
> --tag CC
> Eric,
> Could you try following simple fix:
> 1. Open GDALmake.opt.in file
> 2. Go to line 19
> 3. Replace
> CC  = $(LIBTOOL_COMPILE) @CC@
> CXX = $(LIBTOOL_COMPILE) @CXX@
> with
> CC  = $(LIBTOOL_COMPILE) --tag CC @CC@
> CXX = $(LIBTOOL_COMPILE) --tag CXX @CXX@
> 4. Run ./configure and see if it helps
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
