[Gdal-dev] GDAL maintenance biweekly report - No. 2
Mateusz Loskot mateusz at loskot.net
Mon Apr 2 22:41:17 EDT 2007
Here is the second biweekly report:
Resolved issues:
HFA reading code does not handle reduced precision properly
http://trac.osgeo.org/gdal/ticket/1000
XYMZ data in WKT leads to an error
http://trac.osgeo.org/gdal/ticket/1036
gdalnumeric does only support old Numeric package
http://trac.osgeo.org/gdal/ticket/1166
Naked ewkb from postigs (queried through python) causes OGR to segfault
http://trac.osgeo.org/gdal/ticket/1195
XYZM data cannot be read from wkb
http://trac.osgeo.org/gdal/ticket/1323
problem w/ date fields using ogr2ogr to load shapefile into postgis
http://trac.osgeo.org/gdal/ticket/1389
Additional fixes to VSI*L and "errno" setting.
http://trac.osgeo.org/gdal/ticket/1429
[OGR] Seg fault in ~OGRKMLDataSource()
http://trac.osgeo.org/gdal/ticket/1432
(Partially fixed) GetFeature() not implemented efficiently for server
based drivers
http://trac.osgeo.org/gdal/ticket/1445
class ERSHdrNode has no member named FindElem
http://trac.osgeo.org/gdal/ticket/1522
GIMP JPEG error, Spaced World File error
http://trac.osgeo.org/gdal/ticket/1523
Setup Nightly Snapshots
http://trac.osgeo.org/gdal/ticket/1539
Investigated and issues in progress:
dal
[OGR-ODBC] : DECIMAL field not recognised
http://trac.osgeo.org/gdal/ticket/1321
NHD (ESRI) geodatabase reading problems
http://trac.osgeo.org/gdal/ticket/1484
Random crashes when using OGR SQL in -where clause
http://trac.osgeo.org/gdal/ticket/1528
Patch for mingw bug in strdup
http://trac.osgeo.org/gdal/ticket/1547
Other tasks:
1. Added or improved tests of:
- FAST
- OGR PG
- HFA
2. GDAL sources refactoring and improvements
3. Cleaned 300 reports on Bugzilla after migration to Trac
4. SWIG Perl tests added to Buildbot
5. Tested GDAL with MinGW buildbot configuration (deferred)
6. Provided support (>30 posts)
7. Ad-hoc troubleshooting
8. Investigated and tested building SWIG Java, for Buildbot (deferred)
Mateusz Loskot
http://mateusz.loskot.net
