[Gdal-dev] problems with average
Thekla Wirkus thekla.wirkus at wheregroup.com
Tue Apr 3 08:19:59 EDT 2007
the problem is undissolved. With
gdaladdo -r nearest bild_8bit.tif 2 4 8 16
the result-TIF has mistakes at page 2-5 too.
Best regards
Thekla Wirkus
Frank Warmerdam schrieb:
> Thekla Wirkus wrote:
>> Hi,
>> I have problems with creating a multipage-TIF with:
>> gdaladdo -r average bild_8bit.tif 2 4 8 16
>> the result-TIF has mistakes at page 2-5, page 1 is OK. The hatches are
>> normally single colors but after using gdaladdo -r average ...
>> they are shown with multicolors and they are blurred.
>> See the result at:
>> http://wms1.ccgis.de/mapbender_dev/tmp/ergebnis_bild_8bit.tif
> Thekla,
> Average downsampling is inappropriate for discontinuous images.  That
> is images where nearby pixel values are not necessarily nearby colors.
> Your image has a colormap (and not just a continuous color ramp) and so
> fall into this category.
> You should use the default nearest neighbour downsampling instead of
> using "-r average".
> Best regards,
Mit freundlichen Grüßen
Thekla Wirkus
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 16
Fax: +49 (0)228 / 90 90 38 - 11
mailto:info at wheregroup.com
http://www.wheregroup.com
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRA 6788
