[Gdal-dev] Question on building external overviews
Wed Apr 4 09:44:21 EDT 2007
Stephen Woodbridge wrote:
> Hi guys,
> I took this approach to building external overviews, but all my images
> seem to be gray in mapserver and appear to be all nodata values in the
> file. Any idea what I'm doing wrong here?
> I have a directory of of 16x16 tiles that fill a one degree block.
> I want to make 4x4 overview files with 4x4 of the original tiles.
> ie: 4x4 original tiles into 1 overview
> So for the first tile, I create the output tile like this
> gdal_translate -of GTiff -co \"TILED=YES\" -outsize 3200 3200 -a_srs
> EPSG:4326 -a_nodata 0 -a_ullr $top $left $bot $right $inf $outf
> then for each additional tile I mosaic them into $outf like this:
> gdalwarp --config GDAL_ONE_BIG_READ ON -srcnodata 0 -rc -wm 150 $inf $outf
> Any help would be appreciated.
Steve,
I don't see any obvious problem with the process.  When you say they are
grey in mapserver, do you mean "greyscale" or a single constant grey?
If you can reproduce the problem with a small dataset I would be happy to
try it here and comment.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
