[Gdal-dev] Make error "libtool: compile: unable to infertaggedconfiguration"
Patton, Eric epatton at nrcan.gc.ca
Wed Apr 4 10:53:24 EDT 2007
CORRECTION:
"Synaptic reports that the libstdc++6.4.1-dbg package installed libstdc++.a and libstdc++.la in /usr/local/debug"
Should read:
Synaptic reports that the libstdc++6.4.1-dbg package installed libstdc++.a and libstdc++.la in /usr/lib/debug"
Sorry,
~ Eric.
-----Original Message-----
From: gdal-dev-bounces at lists.maptools.org on behalf of Patton, Eric
Sent: Wed 4/4/2007 11:49 AM
To: Mateusz Loskot
Cc: gdal
Subject: RE: [Gdal-dev] Make error "libtool: compile: unable to infertaggedconfiguration"
After some more digging around in Synaptic and installing some more packages, (specifically, unixodbc and libpq), the "unable to infer taggedconfiguration" error has vanished. I proceeded normally with make, and I received and error about libstdc++.la not being in /usr/lib. Synaptic reports that the libstdc++6.4.1-dbg package installed libstdc++.a and libstdc++.la in /usr/local/debug. So I created a symlink for each libstdc++ archive file:
$ pwd
/usr/lib
$ sudo ln -s debug/libstdc++.a libstdc++.a
$ sudo ln -s debug/libstdc++.la libstdc++.la
and re-ran make, which completed without the aforementioned "libstdc++.la not found in /usr/lib" error.
Curiously, though, the last three lines of the 'make install' output read:
ldconfig: /usr/local/lib/libproj.so.0 is not a symbolic link
ldconfig: /usr/local/lib/libgeos.so.2 is not a symbolic link
ldconfig: /usr/local/lib/libgeos_c.so.1 is not a symbolic link
Is this a problem? gdalinfo --version reports:
$ gdalinfo --version
GDAL 1.4.0.0, released 2007/01/02
So, can I assume that I have a healthy GDAL installation?
~ Eric.
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Mon 4/2/2007 3:10 PM
To: Patton, Eric
Cc: gdal
Subject: Re: [Gdal-dev] Make error "libtool: compile: unable to infer taggedconfiguration"
Patton, Eric wrote:
> Hi,
> After making the following edits to GDALmake.opt.in :
> 1. Open GDALmake.opt.in file
> 2. Go to line 19
> 3. Replace
> CC  = $(LIBTOOL_COMPILE) @CC@
> CXX = $(LIBTOOL_COMPILE) @CXX@
> with
> CC  = $(LIBTOOL_COMPILE) --tag CC @CC@
> CXX = $(LIBTOOL_COMPILE) --tag CXX @CXX@
Eric,
Please, could you try this one:
CC  = $(LIBTOOL_COMPILE) @CC@ --tag CC
CXX = $(LIBTOOL_COMPILE) @CXX@ --tag CXX
Cheers
Mateusz Loskot
http://mateusz.loskot.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
