[Gdal-dev] create 256x256 tiles for google maps
Mateusz Loskot mateusz at loskot.net
Fri Apr 6 14:08:06 EDT 2007
Paul Van Deusen wrote
> Mateusz, THanks. This
> is a good suggestion. I tried compiling it but got the following errors.
> It would be a handy tool if it could be made to compile.
> [pvandeus at localhost temp]$ gcc -o gdalsplit -L/usr/local/lib -lgdal
> -I/usr/local/include -I/home/pvandeus/downloads/gdal-1.4.0/frmts -ltiff
> gdalsplit.cpp -Wall gdalsplit.cpp: In function �CPLErr
> CopyRasterBand(GDALDataset*, GDALDataset*, int, int, int, int,
int)�:
> gdalsplit.cpp:233: error: �class VRTRasterBand� has no
member named
> �AddSimpleSource�
Paul,
I'm taking look at this utility.
I'll let you know about results, tonight.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
