[Gdal-dev] create 256x256 tiles for google maps
    Paul Van Deusen
    Paul_VanDeusen at uml.edu
    Sat Apr  7 09:32:49 EDT 2007
Paul Van Deusen wrote:
>> If anyone happens to haave an updated version of "gdalsplit"
>> > I would be interested.
>> > Maybe some mechanism to manage user contributions would be
>> > good (like the GRASS Addons repository).
>> > > Markus
>> > ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
>> > ITC -> since 1 March 2007 Fondazione Bruno Kessler
>> > _______________________________________________
>> > Gdal-dev mailing list
>> > Gdal-dev at lists.maptools.org
>> > http://lists.maptools.org/mailman/listinfo/gdal-dev
>> Perhaps I am overlooking something, or didn't understand the question
>> right, but I regularly create tiles from a large tif-file with the
>> -srcwin <xoff yoff xsize ysize> parameter of gdal_translate. A simple
>> bash-script to tile in.tif (30000*30000 pixels) into 256*256 tiles
>> would be:
>> width=30000
>> height=30000
>> y=0
>> while [ $y -lt $height ]
>> do
>>   x=0
>>   while [ $x -lt $width ]
>>   do
>>      outtif=t_${y}_$x.tif
>>      gdal_translate -srcwin $x $y 256 256 in.tif $outtif
>>      let x=$x+256
>>   done
>>   let y=$y+256
>> done
>> This would result in about 14000 files. This is so simple that it can
>> even be done with a primitive DOS batch file.
>> Most of the time I work with projected coordinates (-projwin instead
>> of -srcwin) but the idea is the same. Note by the way that -projwin
>> uses the *upper* left corner as reference.
>> Jan
> Jan,
> I always like simple solutions.  I put your code into a bash script
> and tried it
> on a 10240x5120 section of a tif file.  I applied imagemagick to the
> full file using
> convert nlcd.tif -crop 256x256 tiles%d.tif
> Imagemagick was done in a couple of seconds, but the shell script took
> several minutes.  Imagemagick wins (I think) because it does
> everything in memory, whereas
> the shell script keeps reloading the full image on each iteration.
> However,
> imagemagick starts to fall apart on very large files.   gdalsplit
> might work better.
> Still your solution was worth looking at.
> Paul
I spoke too soon.  I tried this script on some large files. It keeps
chugging along and
finishes the job ahead of imagemagick on very large files.  So it is a
solution.
