[Gdal-dev] Re: autotest-coverage.txt [was: GDAL maintenance biweekly report - No. 1]
Mateusz Loskot mateusz at loskot.net
Sat Apr 7 17:05:21 EDT 2007
Maciej Sieczka wrote:
> Mateusz Loskot wrote:
>> 3. Started analysis of GDAL tests coverage:
>> http://mateusz.loskot.net/tmp/gdal/autotest-coverage.txt
> If that's usefull, a sample NDF (NLAPS Data Format) sample can be found
> here:
> ftp://edclpdsftp.cr.usgs.gov/SAMPLE/DATA/L5_MSS_NDF
> linked on:
> http://landsat.usgs.gov/data_products/sample_products.php
Maciej,
Thanks, I'll check these samples.
FYI, I've moved the autotest status from the raw text file to the Wiki:
http://trac.osgeo.org/gdal/wiki/AutotestStatus
Cheers
Mateusz Loskot
