[Gdal-dev] why does r.out.gdal break other stuff?
Paul Van Deusen Paul_VanDeusen at uml.edu
Mon Apr 9 12:22:22 EDT 2007
I just noticed that configuring gdal using the --with-grass option
breaks things that used to work.
Is there anyway to have r.out.gdal working without sacrificing other
gdal capabilities.
For example, I could no longer run gdalinfo after compilation using the
--with-grass option.
I found this description of the problem.
http://grass.itc.it/pipermail/grass5/2004-October/015804.html
