[Gdal-dev] Instructions for Cygwin compile of GDAL
Norman Vine nhv at cape.com
Fri Apr 13 06:29:03 EDT 2007
Alessandro Amici writes:
> Norman,
> On Friday 13 April 2007 01:44, Norman Vine wrote:
> > Shouldn't have to change anything
> > To check I just did a fresh Cygwin install and
> > ./configure --with-libtool=no; make; make install
> >   < might work with libtool I don't know I just can't stand the
> >     glacially slow Cygwin compiles with libtool >
> in order to avoid the double compile with libtool you may use
> the '--disable-static' (tested on unix/linux) or
> '--disable-shared' (maybe on cygwin, but not tested) options.
> this is not as fast as '--without-libtool', but much, much closer.
> if you test it on cygwin (i don't have a cygwin install at
> hand, currently), please report back how it goes.
Alessandro
Libtool's 'glacial pace' is due to the many levels of indirection
that it forces.
Cygwin is not Linux.  :-)
Cheers
Norman
