[Gdal-dev] GDAL C API and Delphi
Fri Apr 13 10:19:18 EDT 2007
Artur Redzko wrote:
> Hi
> Is there any special procedure to build GDAL DLL, that can be mapped and
> used in Delphi through C API. I built DLL using Visual C++ express 2005,
> tested exports using dumpbin - it looks fine. But when I try to map it
> in Delphi like :
> I tested it with daily and gdal 4.1 source with default settings. I also
> tried to get binaries from vterrain but they also don't work. Strangely
> found old 1.2 version works.
> Can anyone help me ? What do I do wrong ?
> Can someone send me compiled binaries for Windows ?
> Ps. Sorry for doubled emails. I have problem with my email server.
Artur,
GDAL 1.4 should build with most GDAL C API entry points using stdcall
conventions.  I don't know why things aren't working for you, except
possibly limitations with the express compiler.
You might want to grab FWTools and try with that GDAL_FW.DLL.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
