[Gdal-dev] HDF MODIS conversion to GeoTiff WGS-84 referenced format
guillaume huby guillaume.huby.lists at gmail.com
Fri Apr 13 10:44:17 EDT 2007
On 4/13/07, mattia <mattia.parigiani at gmail.com> wrote:
> Hey! Thanks a lot, I seem to be getting my Tiff images ok.. Even though
> they are all really dark and cant see much out of them.. Is that right
> anyways??
> One more thing I had mentioned in the previous mail is that I need to
> obtain also the TWF file that accompanies each TIFF file.. This file
> specifies pixel resolution and upper left coordinates of images bounding
> box.. Does anyone have a clue on how to obtain this??
> For what regards merging the images, I do not have the gdalmergecommand... only the
> gdalwarp one.. Is this because of my gdal version... Where can I get the
> CVS version from? I've been looking for it but was not lucky in my search..
> Can you, or anyone, also help me with the gdalwarp syntax given a series
> of .tif files and wanting to merge them into a single viewable one??
Having a look at http://www.gdal.org/index.html should help you a lot to
answer your questions ...
For tfw files, add option -co "TFW=YES".
Regards,
Guillaume.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070413/46c246ea/attachment.html
