[Gdal-dev] HDF MODIS conversion to GeoTiff WGS-84 referenced format
mattia mattia.parigiani at gmail.com
Fri Apr 13 11:57:24 EDT 2007
Thanks a lot again,
Tried to gdal_translate with the -co "TWF=YES" option.... Cant see the .twf
file though... do I have to tell it where to store it or ?? where is it
getting stored? any idea?
Again,
Mattia
On 4/13/07, guillaume huby <guillaume.huby.lists at gmail.com> wrote:
> On 4/13/07, mattia <mattia.parigiani at gmail.com> wrote:
> > Hey! Thanks a lot, I seem to be getting my Tiff images ok.. Even though
> > they are all really dark and cant see much out of them.. Is that right
> > anyways??
> > One more thing I had mentioned in the previous mail is that I need to
> > obtain also the TWF file that accompanies each TIFF file.. This file
> > specifies pixel resolution and upper left coordinates of images bounding
> > box.. Does anyone have a clue on how to obtain this??
> > For what regards merging the images, I do not have the gdalmergecommand... only the
> > gdalwarp one.. Is this because of my gdal version... Where can I get the
> > CVS version from? I've been looking for it but was not lucky in my search..
> > Can you, or anyone, also help me with the gdalwarp syntax given a series
> > of .tif files and wanting to merge them into a single viewable one??
> Having a look at http://www.gdal.org/index.html should help you a lot to
> answer your questions ...
> For tfw files, add option -co "TFW=YES".
> Regards,
> Guillaume.
Mattia
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070413/45f63dc7/attachment.html
