[Gdal-dev] New builder for stable branch
Mateusz Loskot mateusz at loskot.net
Fri Apr 13 15:11:24 EDT 2007
I added new builder to the GDAL Buildbot instance: telascience-stable
http://buildbot.osgeo.org:8500/telascience-stable
This builder is dedicated to build current stable branch
(ATM, it's branches/1.4).
It's configured to run incremental builds, the same way as -quick
builders work.
It's also possible to build branches using -quick and -full builders,
but it takes long time, because Buildbot has to remove current source
tree, do fresh checkout and then run complete build.
Having a dedicated builder the process of testing stable
branch is much shorter.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
