[Gdal-dev] Instructions for Cygwin compile of GDAL
Roger André randre at gmail.com
Fri Apr 13 19:16:24 EDT 2007
The --with-python option is one I hadn't seen before.
I'll try it again, and with the --with-libtool=no option, since I'd like it
to finish in the next 45 minutes.
Thanks,
Roger
On 4/13/07, Norman Vine <nhv at cape.com> wrote:
> Roger André writes:
> > Sorry, didn't work.  See results below.
> > Roger at obelix /cygdrive/c/gdal/gdal-1.4.1 $ ./configure --disable-shared;
> make; make install
> > Roger at obelix /cygdrive/c/gdal/gdal-1.4.1 $ python Python 2.5 (r25:51908,
> Mar 13 2007, 08:13:14) [GCC 3.4.4 (cygming special, gdc 0.12, using dmd >
> 0.125)] on cygwin Type "help", "copyright", "credits" or "license" for
> more
> information.
> > >>> import gdal
> > Traceback (most recent call last):
> >   File "<stdin>", line 1, in <module>
> >   File "/usr/lib/python2.5/site-packages/gdal.py", line 191, in <module>
> >     import _gdal
> > ImportError: No module named _gdal                  <======== Boom!
> Hmm   I believe my example was
> ./configure --with-libtool=no --with-python
> Note I installed Cygwin on a clean machine just to test
> if GDAL still worked in Cygwin
> Good Luck
> Norman
> $ python
> Python 2.5 (r25:51908, Mar 13 2007, 08:13:14)
> [GCC 3.4.4 (cygming special, gdc 0.12, using dmd 0.125)] on cygwin
> Type "help", "copyright", "credits" or "license" for more information.
> >>> import gdal
> >>> gdal.__file__
> '/usr/lib/python2.5/site-packages/gdal.pyc'
> >>> a = dir(gdal)
> >>> a[:4]
> ['AllRegister', 'AutoCreateWarpedVRT', 'Band', 'CE_Debug']
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070413/72aab18e/attachment.html
