[Gdal-dev] Java binding - supported file format.
Daniel Siino drsiino at gmail.com
Mon Apr 16 13:46:02 EDT 2007
I am able to read ESRI and TAB files using  the ogrinfo tool but I get:
"ERROR 4: `d:\data\world.shp' not recognised as a supported file format."
when running
java -cp build\classes;apps gdalinfo d:\data\world.shp
Am I missing some file in my path?
I have build the Java binding using nmake and swigwin-1.3.31.
I've only got a few warnings during the process:
Warning(453): Can't apply (IF_ERROR_RETURN_NONE). No typemaps are defined.
Warning(302): Identifier 'Geometry' redefined (ignored) (Renamed from
'OGRGeometryShadow'),
 Warning(302): previous definition of 'Geometry' (Renamed from
'OGRGeometryShadow').
Warning(453): Can't apply (double argout[ANY]). No typemaps are defined.
Regards,
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070416/e5bbc255/attachment.html
