[Gdal-dev] RE: GDAL C API in Delphi
Artur Redzko artur.redzko at tatukgis.com
Wed Apr 18 03:40:47 EDT 2007
Thanks for reply. I hope Frank will agree to add this feature. If he does, please check def file if it's complete:
- Someone posted info about missing color table access in C API,
- I also noticed new functions with RAT prefix,
- Maybe additional memory management functions like alloc and free should be added to C API to avoid memory crashes.
I used different GDAL versions including latest daily that's why I prefer to test this feature. I'll also try to prepare a test app in Delphi to test DEF file and C API binding for all function names.
Hoping to include DEF feature successfully into GDAL..
Pozdrowienia / Regards
Artur Redźko
www.TatukGIS.com
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Tuesday, April 17, 2007 8:27 PM
To: Artur Redzko; gdal
Subject: Re: GDAL C API in Delphi
Artur Redzko wrote:
> I hope that dev team will make use of this and import it gracefully
> into GDAL sources for further tests.
Frank,
Should I try to include Artur's solution and DEF file to GDAL ?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
