[Gdal-dev] Transform Line String into Polygon with ogr2ogr
Wed Apr 18 09:18:36 EDT 2007
On 4/17/07, Lijian Shi <lijian.shi at und.nodak.edu> wrote:
> I have a shp file with Line String geometry type. Actually these lines are
> polygon because the coordinate values of line string's first point are same
> with them of line string's last one. Now I want to transform this shp into a
> new one with polygon and I use command "ogr2ogr" as:
> ogr2ogr new.shp old.shp –nlt POLYGON
> But there are some errors as followed:
> ERROR 1: Attempt to write non-polygon (LINESTRING) geometry to type
> shapefile.
> ERROR 1: Terminating translation prematurely after failed
> Translation of layer zones
> Can I use this "ogr2ogr" to convert LINESTRING into POLYGON? If yes, what's
> the problem with my command?
Lijian,
I'm afraid there is not support for automatic conversion of
geometry types in ogr2ogr.
Best regards,
