[Gdal-dev] Re: GDAL C API in Delphi
Wed Apr 18 10:00:20 EDT 2007
On 4/17/07, Mateusz Loskot <mateusz at loskot.net> wrote:
> Artur Redzko wrote:
> > I hope that dev team will make use of this and import it gracefully
> > into GDAL sources for further tests.
> Frank,
> Should I try to include Artur's solution and DEF file to GDAL ?
Artur,
i'd appreciate your filing a proper ticket at:
  http://trac.osgeo.org/gdal
I skimmed your earlier message, but the text didn't really tell
me anything about what the problem turned out to be, and I
didn't have the time to dig through the zip file.
Assuming there is a clear action item, I'll have Mateusz take
care of it.
Best regards,
