[Gdal-dev] Re: GDAL C API in Delphi
Ivan Lucena ivan.lucena at pmldnet.com
Wed Apr 18 10:42:01 EDT 2007
Frank,
Since Artur is not a GDAL committer and I am assuming that Mateusz doesn't
have a Delphi developer environment at his disposal, I am offering my help
on that matter, if it is needed.
Regards,
Ivan
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank Warmerdam
Sent: Wednesday, April 18, 2007 10:00 AM
To: Mateusz Loskot
Cc: gdal
Subject: Re: [Gdal-dev] Re: GDAL C API in Delphi
On 4/17/07, Mateusz Loskot <mateusz at loskot.net> wrote:
> Artur Redzko wrote:
> > I hope that dev team will make use of this and import it gracefully
> > into GDAL sources for further tests.
> Frank,
> Should I try to include Artur's solution and DEF file to GDAL ?
Artur,
i'd appreciate your filing a proper ticket at:
  http://trac.osgeo.org/gdal
I skimmed your earlier message, but the text didn't really tell
me anything about what the problem turned out to be, and I
didn't have the time to dig through the zip file.
Assuming there is a clear action item, I'll have Mateusz take
care of it.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
