[Gdal-dev] Re: GDAL C API in Delphi
Mateusz Loskot mateusz at loskot.net
Wed Apr 18 15:21:42 EDT 2007
Ivan,
No, I don't have Delphi environment, but if there is any free like VC++
2005 EE, I can install it if that will help us to solve GDAL problems
for Delphi users.
I've been programming with Pascal quite a long time ;-)
Mateusz
Ivan Lucena wrote:
> Frank,
> Since Artur is not a GDAL committer and I am assuming that Mateusz doesn't
> have a Delphi developer environment at his disposal, I am offering my help
> on that matter, if it is needed.
> Regards,
> Ivan
> -----Original Message-----
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank Warmerdam
> Sent: Wednesday, April 18, 2007 10:00 AM
> To: Mateusz Loskot
> Cc: gdal
> Subject: Re: [Gdal-dev] Re: GDAL C API in Delphi
> On 4/17/07, Mateusz Loskot <mateusz at loskot.net> wrote:
>> Artur Redzko wrote:
>>> I hope that dev team will make use of this and import it gracefully
>>> into GDAL sources for further tests.
>> Frank,
>> Should I try to include Artur's solution and DEF file to GDAL ?
> Artur,
> i'd appreciate your filing a proper ticket at:
>   http://trac.osgeo.org/gdal
> I skimmed your earlier message, but the text didn't really tell
> me anything about what the problem turned out to be, and I
> didn't have the time to dig through the zip file.
> Assuming there is a clear action item, I'll have Mateusz take
> care of it.
> Best regards,
Mateusz Loskot
http://mateusz.loskot.net
