[Gdal-dev] error compiling gdal-grass against latest gdal + potential fix?
Matthew Perry perrygeo at gmail.com
Thu Apr 19 23:20:21 EDT 2007
Hey folks,
 I ran into some minor troubles getting gdal-grass plugin (version
1.3.2) installed on gdal:
./configure --with-gdal=/usr/local/bin/gdal-config
--with-grass=/usr/local/grass-6.3.cvs
g++ -Wall -fPIC  -DUSE_CPL
-DGRASS_GISBASE=\"/usr/local/grass-6.3.cvs\" -I/usr/local/include
-I/usr/local/grass-6.3.cvs/include   -c -o grass57dataset.o
grass57dataset.cpp
grass57dataset.cpp: In static member function 'static GDALDataset*
GRASSDataset::Open(GDALOpenInfo*)':
grass57dataset.cpp:828: error: invalid conversion from 'int (*)(char*,
int)' to 'int (*)(const char*, int)'
grass57dataset.cpp:828: error:   initializing argument 1 of 'int
G_set_error_routine(int (*)(const char*, int))'
make: *** [grass57dataset.o] Error 1
Is there an updated gdal-grass plugin for 1.4.1 that I'm missing?
For the record, changing the following lines seems to fix it.
------ grass57dataset.cpp: 799
typedef int (*GrassErrorHandler)(const char *, int);
------  ogrgrassdatasource:91
I can't confirm that the above changes work but at they compile at the
very least ;-)
Matthew T. Perry
http://www.perrygeo.net
