[Gdal-dev] Error building gdal/ogr: undefined reference to `_gfortran_ ...
Mateusz Loskot mateusz at loskot.net
Mon Apr 23 08:21:03 EDT 2007
Hernán De Angelis wrote:
> Hi Mateusz,
> Thanks for your fast answer. Below you will find the configure
> command and the output. I am afraid I do not undesrtand the
> epimetheus thing.
> Thanks!
> My configure command is:
> ./configure --with-pg=/usr/local/pgsql/bin/pg_config
> --with-netcdf=/usr/local --with-png=/usr/lib --with-libtiff=internal
> --with-geotiff=/usr/local --with-jpeg=/usr/lib
> --with-geos=/usr/local/bin/geos-config --with-perl --with-python
> --with-sqlite --with-odbc
Could you run "make clean" first and then add --without-libtool
option to your configure command and make again, and see if that will work.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
